Hmmm...
'98 Silvermist GT
Open Cone Intake
L26 Aluminum UIM
PEM's
Cat & U-Bend Delete
ZZP HV3
Ported/Polished LIM
AL606's gapped @ .050"
Anchor Solid Engine/Trans Mounts
ZZP Poly Squares/Bushings
Lots of deleted brackets and other crap
180* with the dexcool delete mod
DHP Powertuned PCM running 33* Timing WOT
Fer teh blue retarded mess....
Engine:
Bulldog Racing Engines Balanced and Align Bored L67 3800 Series II V6
ARP Head Studs
ARP Main Studs
Clevite77 Main/Cam/Rod Bearings
Balance Shaft Deleted
GM '04+ L32 Powdered Connecting Rods
GM '04+ L32 TTY Rod Bolts
GM '03 8.5:1 Compression L67 Pistons
Thrasher Engineered Performance Race Camshaft (.574/.566 114 LSA)
GM LS7 Lifters
Comp Cams Rocker Arm Bolts
Intense-Racing O/R Stock Length Pushrods
Bulldog Racing Engines Custom Ported/Polished L67 Heads
Manley #130 Valve Springs
Manley Titanium Retainers
GM OEM Valve Guides Milled .100" for cam clearance
GM '04+ L32 Valves
Comp Cams Valve Locks
Viton Valve Seals
Ported Lower Intake Manifold Inlet/Runners
Ported Factory GM GenIII M90 Supercharger:
-Rebuilt using OEM GM Seals/Fluids/Bearings
-Ported Inlet/Outlet
-Machined Supercharger snout for use of pulleys smaller than 2.90"
Custom LS1 Throttle Body Setup/Polished Adapter Plate
SLP 85mm MAF w/ 9" Open Cone Intake Setup
ZZPerformance Modular Pulley System: 3.2"/3.0"/2.8"
160* Thermostat
Custom HP Tuners Tuned PCM
Stainless Steel Catless Headers
3" Custom Catback w/ 4" G8 GXP Tips, 26" glasspack as a resonator and a 9" Bullet Proflo muffler before the "Y"
MSD Ignition Coil Packs
MSD Ignition 8.5mm Spark Plug Wires
Autolite 103 Copper Core Spark Plugs
Transmission:
Triple Edge Performance Built 4T65E-HD
3.29 Gears
Trans-Go Shift Kit
Full Rebuild with Hardened Clutches/Bands
Hardened 4th Shaft
7/8" Single Chain Setup
Allison TransSend Transmission Fluid
Suspension:
Springtech Lowering Springs (1.8"-2" Drop All Around)
ZZPerformance Anti-Pogo Washers
GMPP Front Sway Bar
GMPP Rear Sway Bar
GMPP Rear Trailing Arms
GM OEM 12" Brake Upgrade
Drilled and Slotted Front/Rear Rotors
ZZPerformance Poly Engine Mount
ZZPerformance Poly Transmission Mount
ZZPerformance Poly Round/Square Upper Mounts
engine mods:
07 N/A 3800
wizair cai
hv3
flipped dog bones
synthetic oil
coming soon:
er rockers
hears my modz:
2000 se
ram aire intake with HUGE filter
strate pipe exhuast
ebay chip
msd coils and wire
platinum 4prong pluigs
prob pushing about 300 whp, na
