tgarison
Hey Forum,
We just had our first freeze of the year in Texas and I went out to start my GPGT and when I did the Low Coolant light turned on and would not go out so i just added some coolant to it. Well now it's done that every time i've started it with the engine "cold", so I checked all around the engine and there is wetness all around the outer lower edge of the LIM. I'm thinking the plastic LIM gaskets are failing. And to save you all the trouble of asking I checked and the coolant is not mixing with the oil surprisingly enough. Also my engine temp gauge isn't reading the same as what the computer is seeing the computer for example is seeing 205 degrees and the gauge is showing 170. Any thoughts?
