pop in front end when accelerating or stepping on the brakes
What have you already checked/replaced? Year, model?
Id start by checking to see if your sway bar is broken as that's the easiest to check. And it's free. I'd move to ball joints after that if the sway checks out okay.
Could be LCA bushings as well.
Could also be subframe bushings.
id check the front subframe bushings or the control arm bushings.... i just did my control arms because the bushing on it slid down and the metal on the control arm was smashing around
