po302 misfire after bad overheat...
basimpo
Hello all I'm back again with a new/old problem. I have a 2003 3.1l with 173,000 miles.The other day my water pump went out on me on the freeway and the car shut off. I limped it home. Drove it to the auto store the next day, it was overheating, andback home. Replaced the water pump,and a couple hours later went to fill it with water. At this point I accidentally sprayed the coils and top of the engine pretty good with the hose.
After filling and bleeding the system I noticed a check engine light came on and began blinking. I pulled the code and it was a po302.
I checked for spark at the coil pack which it had and then I pulled the plug. The plug was fouled up pretty thickly and it had wet fuel on it that soon evaporated. I replaced the plug with a new one and the car ran good for about a block, no misfire at all according to my creader crp123 but then started flashing the service engine light, and registering misfires on 2 again.
Any clues aside from you shouldn't run water in the cooling system? Oh and I've bypassed the heater core and removed the thermostat btw.
Thanks!
Try some electrical grease on the coil packs and plug.
Maybe even mist the wires late at night with water and watch for a spark jump, that will a show a misfire related to a faulty coil or wire arching.
Or you overheated it so bad that it blew the head gasket and now has low compression in that cylinder.
Nope I blew a head gasket. I was blowing white smoke. 30 minutes with blue devil stopped the smoke. 50 minutes and the misfire disappeared. I've gone about 377 miles since I posted/ poured the blue devil and neither smoke nor misfire has apppeared :)
