Po108
davidl25
I had this code pop up. It was the MAP sensor. I changed it still same code keeps poping up. When its warm it starts chugging and popping in the intake. What could this be. It only does it when warm.
chugging and poppin in intake is fuel= fuelpump.. do you have the spring and o rings in the pcv valve under neath the map if not that will cause code to set
yes the pcm is tuned for the #24 injectors. I put the bigger injectors in about a year age. This problem just started.
