So you want to improperly gap your new plugs, because the old ones you took out were improperly gapped? If your spare tire had 0 psi in it when you first checked it, would you keep it at that pressure, or put it where it's supposed to be?
lol, did you fall for a "stage kit"?
Please say, no.
Regardless, the catback is the least of any flowing issues.
Send it back and get a Downpipe (with a u-bend delete...because that is the REAL issue).
As for the plugs...run better plugs. Autolite cheapo copper core 104's. Gap them at ..050". It works. 100/100 times.
Not at all, but in my defense I asked this question earlier and no one answered it....
But are there any scenarios you can think of that would call for a setting such as that?
Are people still going to tell me it is 100% totally wrong to use a smaller pulley and not put on headers? Its those type of misconception that I am trying to weed out. I am no expert but I know that is also 100% false.
I also asked earlier, First question: After 100k miles +/- 5k or so. How much do you suppose the gap would open up during that time?
Again no one answered the question but had no problems telling me I am wrong. If I am wrong, why?
To answer your first question it totally depending on plug type/brand. A copper plug will be litterely nothing after 60-70k miles, seen it many times of chrysler motor from jeeps/dodge's. Like almost double the factory spec.
Iridium tipped plugs are made to last 100k in most vehicle, the gap from what I've seen might have moved 5%?? Done alot of plug changes on Vortec LS truck motors and they are fine gap wise but old plug wise and need of changing.
Not saying they couldnt open up more but it's not super common and nobody is going to have hard data to back anything up here.
And dropping pulleys without anything else is still a bad idea, unless you are running some 100-116 octane fuel all the time. And your first first question, incorrect plug gap won't cause a rotten egg smell. If the vehicle does not have a misfire, no real unburned fuel left to smell because the cat converter is there to burn up the rest.
Not sure who told you headers were a REQUIREMENT for a smaller pulley, but that's no reason to just assume a .070 gap is ok when spec calls for .060. You're wrong because the damn spec calls for .060, google it if you want. I thought the gap specs were pretty much common knowledge.
I was just confirming. I was unsure if the mods would change the gap specs. It is frustrating because I do not have the paperwork for the mods and the specifics of it. The specs also call for a certain serpentine belt, but I know I cant just go to Autozone and say give me a SC belt for a 01 GTP and expect them to give me the right one. Its reasons such as that why I was questioning the gap.
