John_Shughart
oK please let me know if you have any input or advice but here is the problem.
1. I have put a new suspension set up on my 04 GTP. i used Eibach springs and KYB struts on the rear. also put in a GM performance Sway bar and GM performance Trailing arms on the rear.
2. After putting it down i had a vibration. so i have performed the following.
1.Balanced All tires. One was bent.
2. replaced the bent wheel. Vibration still there
3. Had the Stealership do a super wam-a-dine balance test on the wheels. Turned out i had another bent wheel. Jackasses that replaced the first one replaced it replaced the wrong one. ordered a new wheel they put it on and the vibration is still there.
I have no idea what in the world could be causing this and im at my witts end at trying to pin point. so please if you have any input fire away.
