please help!! i washed my car in minus 30... now half my dashlights go out after 10 m
geiger92
2001 gt coupe
Sent from my SGH-I747M using Tapatalk
washed it in minus 30 now this happens after ten mins of driving it... they work great at first than that and it drives me nuts.. :(
Take off the front trim bezel and take the two screw to remove the gauge cluster. There are 3-5 bulbs that illuminate the dash. Just replace them, it's like a 194 bulb if I remember correctly. It probably has nothing to do with the fact that you washed it unless there is water back there too.
Mine does this! I thought it was some kind of heat related issue. Do you just get regular 194s or the ones with the special connections
Sent from my Lumia 900 using Board Express
live in canada was minus 50 for a few days than 30 didnt feel to bad
plus highways are good and hate salt I just silicone lube my door trims n wipe em after I was doesnt stick
These have the odd bases on them where the wire terminals from the bulb are spot welded to the contacts. You can make plain 194 bulbs work by bending out the wire terminal and kind of " trap " it between the contact and base.
yeah I start it in the morning and they work great 10 mins later they do that.. I imagine once ones goin sends a couple out cause yeah the way the twist in.
