Pontiacmaster81
So recently Buffalo NY had a massive snow storm past week. So I went to go start my car that was engulfed with snow all around it. I made sure to get out the Exhaust Tip so it would not seep inside. I turned the heat on full blast, while I'm outside trying to dig out this massive snow automotive. Came inside the car to get warmed up and noticed a mild plastic rubber smell. Yet it went away after I turned the heater off. I noticed that the HVAC Blower Motor underneath the passenger dash the wiring is really outdated. Meaning if you move the wire to much the Blower Motor turns off and no heat come out. So I don't know if it's the Heater fan/motor assy that's causing this distinct order or something else.
Also on the Electrical-Switch & Relay : A/C and Heater Control Switch the A/C button does not work. you can press and press and hold it in but A/C don't turn on. So maybe this is another reason for the smell or perhaps it's both
Any thoughts
Any thoughts
