pistons
wking2
about to install forged pistons in my car with a turbo, not sure if i should buy the coated ones or not. I also dont know what you guys recomend, the JE or diamond pistons.
Stage 2 heads by intense 130lb springs, cartuning turbo with stattama 67 turbo. l32 rods, stage 3 cam from zzp. hv3, dont know if i need to do piston work or not, car has only 40,000 miles on it
You can't used your stock pistons anyways.... Different wrist pins.
Yeah, those pistons are probably good.
Do research on them first though.
To be honest you COULD just leave your bottom end stock....
It'd save you a lot of money.
Wouldn't limit power too much.
Just intercool and make sure you have a good tune and wideband running all the time.
