Phenolic North Star Throttle Body Adapter Gen 5 Electrical adapt Bracket $139.99
sseilmnop
LaBarge Supercharged
[TABLE="width: 1022, align: center"]
[TR]
[TD]
1" Thick Phenolic North Star Throttle Body AdapterNorth Star to Gen 5Includes Electrical Adapters and Throttle Cable BracketTuning is required!This allows you to use the 75mm inlet/outlet 2000+ Northstar throttle body with a L67(Gen 3) supercharger
Maintains proper functional PCV
This allows you to use the 75mm inlet/outlet 2000+ Northstar throttle body and the LQ4 MAF sensor onto you Generation 5 L32(Gen 5) supercharger.The throttle body adapter is able to be mounted upside down for more hood clearance.Then Gen 5 supercharger inlet is already 75mm so no additional porting is requiredElectrical Adapters​
MAF Adapter for LQ4 MAF to series II engine harnesses The LQ4 MAF has its own IAT sensor built in, so with this harness it will adapt the factory IAT and MAF plugs into one plug that will connect to your LQ4 MAF sensor.TPS Adapter for flat style TPS connector to a round style for use with North Star throttle bodies
[/TD]
[/TR]
[/TABLE]
attachment.php
www.ebay.com/itm/112433699184
This is sweet!! I'm sure it doesnt make a huge difference being phenolic, but everybit helps anf for only 10$ more then the standard one thats a smoking deal.
Sent from my LG-H830 using Tapatalk
