PERF SHIFT light?
RichCresci
on my dash a have a PERF SHIFT light but its never lit up. Anyone know what its for? Thanks
Also, one of my dash lights behind my gas gauge went out so part of my dash is darker than the rest. any clues on how to change it? thanks again.
Do you have the performance shift button on the side of your shift knob? As for changing the bulb in your instrument cluster, you have to pop off the trim panel from around it. It's a pretty big peice so don't let it scare you. It will also seem like youe about to break it, but you have to pull kinda hard to get it to pop loose. A couple clips might come of and you should be able to retreive them from under the dash. There's a cover under there you can pop loose also. Once that is off, unscrew the instrument cluster and look on the backe. You should see these round looking tabs sticking out. Turn either right or left, they only turn one way, and it will slide out with the bulb stuck in it. Figure out wich bulb is blown and put everything back together.
yeah i do, its a gtp sedan. it never lights up though. Thats what i thought i had to do but i wasnt sure. thanks. ill probably do that tomorrow.
mine was the same way take your bulb out of the dumb seat belt light in the middle of the cluster and put the bulb in the spot for perf shift it lights up blue and is sweet haha good luck its easy to do =]
What year model is your car?
