PCV Valve
Pontiacman
I was checking around on some posts and said as part of maintance you should change you PCV valve. Where is it located in the engine compartment? Thanks
Well n/a are on the pass side under the map sensor, and the s/c its under a plate on the dr side, look it up on google, or on here.
I believe the owners manual says 30k miles, or the purolator website I can't remember. Though I've known of people running near 90k and still having a good pcv valve. It's good as long as it rattles when you take it out.
