PCV system and going turbo
nate halter
Hey guys what are you doing with the PCV system when you add a turbo? Cant find alot of info on eliminating it or re-working it. Thanks
Run a breather, pvc hole in the throttle body gets tapped and plugged. And then run a catch can.
Some run a hob, I think that's the word, switch to keep air moving at idle.
Why couldn't you just put a one way check valve to the throttle body so when under vac it works normally then under boost it blocks flow into crankcase?
Its not that its going to find a vent it's that you will dramatically increase oil blow by and likelihood of detonation from oil getting in the combustion
