PCM control just engine or abs and body as well ?
got914
Im thinking of using the GTP supercharged engine in my porsche 914.T
here are adapter plates to bolt to transmission.
But curiosu
does the PCM control just the engine ?
If so i can just swap everything into my car and hit the key.
the pcm for a 3800 will do both engine and the tranny. my guess is you'll need a pcm set up like a off road buggy would use.
Right, controls both motor and transmission. No ABS, BCM stuff.
BUT, the pcm will go into limp mode/security mode sometimes because the computer does not see the PK3 ignition key. A tune could shut off the security system features.
Hmmmm, yes that seems right, or maybe a 5 speed PCM and theres no trans control to worry about...Did the GTP come 5 speed ?
