Passenger side speaker amp install 2004GP. How should I go through the firewall?
GPfoSHEEZY
I have an amp and sub in the trunk that is going through the door jamb(I know shame on me) and I am about to install another amp under the glove box, but I want to do it right and run wires through the firewall. If anybody could provide a diagram or picture or description of the best place to go through the firewall I would greatly appreciate it.
i took the pass side cowl off and drilled a hole under the windshield. then fed the wire in the hole and it just came out the bottom all easy like.
others will use the rubber block in the pass side floor, or a fire wall grommet.
Im using the rubber block in the passanger footwell scotty mentioned. Works fine,
You can kinda see where it goes, follows a big loom of wire through it.
Thanks guys. I ended up going through the grommet. I didnt even notice the rubber block or else I would have gone through there. My pass side cowl leaks too so I will have to fix that so my equipment doesnt get messed up.
