Frosty
I Write E85 Stickies
Sioux Falls SD
Parting out my 2001 Pontiac grand prix. Most engine and suspension parts will fit any 97+ Wbody car such as impalas and various buicks or just about anything with a 3800. Ask me and I can probably tell you if it will fit. This car made 360whp with a stock cam and stock heads and ran into the 12s on street tires. Also selling anything else that can be unbolted from the car. The engine is blown so I bought a camaro and moved on. All prices are whatever popped into my head so I can negotiate. Ill mark parts as they sell. Shipping depends on where you live but we can talk.
Video of car doing its thing
https://www.youtube.com/watch?v=l9qiBqepivs
Full stack intercooler kit - 650$ - Comes with a fresh Wbodystore GenV core, Bosch intercooler pump, inline pressure / fill cap, beat up but non leaking front mount, modified zzp intercooler fuel rails, 2 spal intercooler fans, and all wiring / accessorys. The wiring harness is custom and allows manual or automatic mode. In automatic mode the pump runs whenever the key is on and the fans kick on whenever engine cooling fans turn on. Seems odd at first but with the right fan programming it ends up controlling intercooler temps perfectly. In manual mode the fans and pump run non stop with or without the ignition turned on. Very VERY useful at the drag strip to keep the loop from heat soaking.
SOLD - Short stack GenV intercooler - 150$ - Barely used genV intercooler core
PENDING - Gen V Eaton M90 supercharger - 200$ - Perfect condition with only slight coating flake, Machined for pulleys as small as 2.55", Fresh oil, recently split the case to inspect and all internals were in very good condition.
PENDING - Lower intake - 50$ - Cut and ported for genV blower and intercooler with coolant channels tapped and blocked. Coolant bypass has been enlarged for better cooling.
PENDING - K & N air intake kit - 150$ - Filter is in very good condition still, Comes with full mounting kit / heat shields and I have intake tubes for stock setups AND for a GenV norstar big maf setup.
PENDING - 60lb ev6 injectors - 150$
SOLD - Full northstar throttlebody / LQ4 MAF kit - 150$ - Comes with Gen V adaptor plate, Throttlebody with all sensors, throttle cable bracket, molded tb to maf hose, MAF, and all wiring harnesses / adaptors to install.
PENDING - 1.9 high ratio rocker arms - 150$ - Modified stock rocker arms for 1.9 ratio from ZZP
PENDING - 105lb comp cams springs - 80$
PENDING - ZZP modified retainers - 20$
8 rib belt kit with balancer - 200$ - 8 RiB balancer with all three pullies. Can also sell the tensioner and mounting brackets needed for a top swap. Also have a few gates belts I can throw in.
SOLD - Speed daddy headers - 120$ - Have a nearly brand new zzp stainless steel flex section welded in and a secondary o2 bung for whatever extra sensor you want to have in it. Comes with stainless band clamps as well. Ill throw in the race gas rated o2 sensor and extension harness. Also comes with adaptors for stock or 3" exhaust.
SOLD - Full ZZP 3" exhaust - 200$ - Aluminized piping, Stainless steel resonator and mufflers. The only way to make your 3800 not sound awful.
PENDING - Addco rear sway bar - 180$ - Rare and no longer avalible. More or less the largest and most stiff sway bar ever built for the Wbody platform. Took me months to find one. Ever felt a front wheel drive car oversteer? Yea that happens with this and youll love it. Larger one in photo.
PENDING - Modified control arms - 50$ - comes with left and right sides both with about 1000 miles on them. Brand new core units from ACdelco with sealed moog ball and socket joints pressed in where the rubber joints are from the factory. Makes for a huge improvement in the front end without the hassel of heim joints that cant handle winter.
Doorman front sway bar - 40$ - not your average stock replacement, doorman managed to make one of the stiffest and best quality sway bars I have ever felt on a wbody.
SOLD - GMPP rear sway bar - 40$ - GM performance rear sway bar, substantial upgrade over stock. Smaller one in photo.
SOLD - ZZP trailing arms - 50$ - Chrome moly trailing arms... get that booty wiggle under control.
SOLD - ZZP strut tower braces - 100$ - or 50$ a piece. Red.
Fbody big brake kit - 150$ - Calipers and brackets. Brackets are black and the calipers are red.
PENDING - Rear heightening springs - 50$ - variable rate to keep the back from sagging and greatly improves launches / handling.
PENDING - Rear o2 simulator / emulator - 30$ - Delete your rear o2 sensor, get rid of your cat without throwing codes, its real simple.
Digital DIC - 50$ - No burnt bulbs, comes with harness.
PENDING - AEM E85 320lph pump and modified factory fuel pump modual - 60$
PENDING - Racetronics fuel pump rewire - 30$
Multec to ev6 adapters - 30$ - Run your nice injectors without cutting factory n/a injector harnesses
Ebay projector headlights with decent led halos and black housings - 50$ - Ill include the relay kit and wiring harness to use these with hids and be able to have low beams + high beams at the same time.
HD differential kit - 200$ - 4t65e owners you can upgrade to a 4t65e-HD with this. Comes with the differential, housing, and cv axle.
Stock rims black - 70$ - All 4 3 spoke style rims. Painted black by someone who isnt completely retarded. Decent shape with some curb rash under the paint.
Nearly new KYB struts - 140$ - all 4 struts with less then 5000 miles on them. KYB gr2s. Complete assemblys with new top plates except for the rear springs unless you want to buy those as well.
PENDING - Transmission with 3.29 gears - 200$ - Fully rebuilt with all updates 40,000 miles ago. Held 360whp no problem. Shift kit.
