How much did the powder coating/ sand blasting cost you? Did the shop know what they were doing or did you have to set it up?
I think I was charged around $75.00 a set for powder coating, blasting added in.
Example, fronts, 4 pieces total = $75.00 add in rears + $75.00 for a total of $150.00 for a full set of 4 calipers with brackets.
Yes, the shop knows what they are doing. They do Big Dog Motorcycles (google it) bike frames. They do about anything, and know what should be and what should not be coated. They have done hundreds of brakes for me, and recently a few M90s for people wanting that done. I drop these parts off never worrying about them.
All i do is disassemble them myself, give them a quick washing in solvent so they dont have any brake fluid in them, and are sorta clean to handle on the out side, and drop them off. Once done, they get a washing to get everything cleaned out of them before they are reassembled.
Replacement parts, such as seals etc. runs around $88.00 or so total for the full set for a set of stock brakes.
For ME to do up a set of brakes, labor of $62.00 ($31.00 a set) and parts of $238.00 or so usually runs around the $300.00 mark when its all said and done for a set of stock brakes.
F-bodies are different, cause I will prefinish the aluminum by hand before it gets power coated, and at owners request, drill and tap the mounting brackets to accept the stock W-Body caliper bolts since I am against using washers/spacers, and smaller bolts on these.
~F~
