P1819
hockeybawler
On my aeroforce gauge it says I have a p1819 code even though I have no CEL. After a quick search it looks like it is a internal mode switch? What is this and what are the symptoms?
Not sure, but here's what a search turned up. Maybe it will make some more sense? Is you neutral safety switch disabled?
From a post on GPONA: Here's the code definition: P1819 Internal Mode Switch - No Start/Wrong Range = PCM, TCM
The generic version of this code is: P1819 Transmission Neutral Safety Switch Short Circuit To Ground
Possible a ground is not on or the round plug that plugs into the transmission got knocked out of place or isn't connected fully/corroded.
The neutral switch is on the inside of the transmissions on these cars.
Oh wow so is it even worth it to try and fix it if my car is running fine or is it something that needs to be taken care of?
