Metal Links
About 2 weeks ago I got p2138(current) and p1125(pending), 04 GP.I replaced the gas pedal and it was fine for a few days then I changed out my battery and it started to come back. Today, while it was raining, it came on 7 times in a 6 mile drive. It seems to trigger when Im cruising between 1000-1400, it'll jump a couple hundred RPMs then fall back or if I stab the throttle.
In last two weeks I have cleaned MAF, throttle body and the throttle wire connector. Clean 3 grounds in the cabin and cleaned the green and blue(?) wire connectors under the driver side dash. About a month ago I also rewired the front driver ABS wire(was water in it) and when I cut into the lower wire loom I accidentally cut a brown and green wire, fixed with solder butt splices. Also installed a strut tower bar.
