Kaiser Pontiac
So, I've been getting this code for a while on my '99 GTP. I've done some reading, and it should either be an issue with the canister or solenoid. I'm guessing a good place to start is the solenoid; I have a spare '97 laying around which looks different, but I'm thinking should work. Question is, can I use this solenoid to test to see if that is the issue? Also, the vac lines...., do those just pull off of the solenoid, or is there a method to removing and not breaking them?
