P0341 OBD-2 code
icolex1
Just finished a complete top end rebuild on the '02 3800 GP. Got rid of the Dex-cool:cool: Hooked up the OBD scanner and had the P0341 code come up. It says it's "Camshaft Position Sensor A-Bank 1 CKT Range/ perf.
Any one got a clue what in the heck that one is??:confused:
I found the answer!!!!! Sometimes when the camshaft sensor wiring harness is mistakenly routed across the top of the coil pack/plug wires it will interfere and cause this error code. Some idiot was in such a hurry to put the top end back together he forgot which way it went (could have been me!!!) I did find it here though.Thanks for all you guys that helped!
http://www.obd-codes.com/p0341
Well it is the camshaft position sensor. It is located on the front timing chain cover. It's either bad,Need a case learn (wich you shouldn't) or you have is unplugged or the wires are cut.
thanks for the info, i'll check it out in the morn. I'd thankl you but I still haven't found the button, yet
The thanks button is located on the bottom right of the post that I already made. Or anyone has already made. But you have to have a minum amount of posts first. I think it's 10 or something like that.
