04lss
I I found out i have a p0341 code. (camshaft position sensor A circuit range/perfromance bank1 or single sensor code. Obviously this has to do with the cam sensor.
I have read that it can be caused by frayed wires, or the sensor failing, or a bad reluctor on the Cam. Which of this is most likely? is there any way i can check before dropping cash on a replacement sensor?
my car is also running bad (intermittently) at idle, and low throttle. could this be the cause?
can i continue to drive it like this or should i park it? (my moms car has a bad starter and ive been letting her use my Daily)
