P0304 Misfire on 1997 GTP
Keith1951
I just read the post where BillBoost says to swap #4 and #1 plug wires to see is the misfire follows the coil. I did that and ran the car for 5 minutes and never got a misfire code ( I'm still getting my nagging P0171). Can you tell me where to go next?
I'd try and find the source of the vacuum leak, that is what the P0171 code is for.
Swap injectors is another thing to try for the misfire, swap the coils themselves to see if the misfire follows. Swapping wires doesn't make sense because cylinder one is on the front and 4 is on the rear.
The reason for swapping 4 and 1 is because they are the same coil pack. I'm still looking for the vacuum leak. The miss went away when I swapped coils but I'm not sold on it being gone since I still have the P0171. I am afraid that as soon as I get rid of the vacuum leak, the misfire will come back. (Murphy's Law!)
No but I have access to one. I keep reading that the P0171 can cause all sorts of problems and is caused by various things so I'm going to replace the EGR Pipe today and if that doesn't fix that I'll start replacing vac lines I hope once the P0171 goes away so will the P0304
Yeah that's what I'm thinking. I've done the brake cleaner spray all over the thing and can't get it to change rpm's
It's Gone!!! I found a hair-line crack in the EGR Pipe under the mounting clamp on the EGR end. I replaced the pipe and the P0304 and the P0171 went away
It will make it run like**** all the time! At least mine did and like BillBoost said, it doesn't show up when you do the brake cleaner trick. It might when youy smoke test it but I never got that far.
We made a fog machine work to test for leaks we found the egr tube was bad in like 5 mins
Sent from my LG-H901 using Tapatalk
