JcGTP39
Okay I'm so stumped on this one guys did everything that I know that could cause this issue. It misses at idle. when you put it in drive you can't feel it cause there's a load on it.
What I've done
New Plugs gapped to .60
New wires
New Colis
Up stream O2 sensor is good replaced that 4 months ago
No Converter
No Downstream O2
Tested the the coil Module like 6 times test out good
Could it be the injectors or possibly a PCM? I just orderd one from zzp for black Friday should get on Wens, tell me what you guys think thank you
What I've done
New wires
New Colis
No Converter
No Downstream O2
