code p0230, fuel pump relay circuit
Car wouldnt start and pump wouldnt prime. Scanned it with my genisys and got the fuel pump relay circuit. I removed the shady walbro install my car had in it and replaced it with a delphi. Hotwire kit was cut up, and one of the plugs on the fuel pump canister was missing and had speaker wires running through it. Safe eh? Figured going back to the factory wiring would have solved my problem. Not so.
Checked wiring under the hood and it seems a wire was tapped from the pcm harness and went to the hot wire kit. Further checking revealed that the pcm harness wire looks burnt in the connector.
Anyone have a wiring diagram for a 2001 gtp? Anyone know if the pcm connector can be opened or if the wire can be taken out and replaced going back to the relay center?
I'll be stopping by a local guy and the dealer for info, but I figured I'd at least check here first.
