Jakegday
hello, i did some searching and found out the p0141 code my engine is now getting is caused by a bad after cat oxygen sensor, or a bad connection between that sensor and the pcm. Is that pretty much the case?? are those the ONLY 2 possibilities, or is there a chance it could be something else??
also, as some of you may have read in my other thread, i just got my car back from the shop on thrusday. it kept throwing a p0171 which was caused by the intake plenum having a hole melted through it right above the EGR port. the shops only guess was that the previous owner let the cat get way to bad before having it replaced. (the cat/exhaust pressure tested perfect)
one of my questions is, since this code was thrown less then a day after getting my car fixed. could it have been possible my p0171 issue was preventing this p0141 issue from being noticed? and now that that is fixed, the pcm can now recognize this problem? is that a possiblility??
im also wondering, IF the previous owner let the cat get way to bad, would that cause the sensor to go bad faster?
and finally, how hard are these to change? are they easy to get to? i took a glance underneath the car and couldnt see it anywhere....
