BadDecisions
Hey guys,
I recently had my car tuned again for the winter upgrades. I'm now having trouble with a P0068 engine code and power limiting. It's making the car virtually undrivable on the hwy.
When I'm getting on the Hwy and try to give it more throttle to merge, the car throws P0068 and goes into limp mode. It's fairly consistent with trying to pass or climb any grade at hwy speeds (basically just before it down shifts this happens)
I've replaced the MAF and traced all the vacuum lines and those are all good. I did noticed that the little foam piece on the upper vacuum fitting on the boost bypass solenoid was gone though. I placed some tape over that fitting and now everything SEEMS ok. Could this be a vacuum leak causing the code? Is it "bad" to have it taped off versus having the foam there?
If it's not this, I think it's in the tune which would be highly inconvenient. Any input would be great. Thanks guys!
