eshina17
Okay I need some help here friends. My 97 GTP has not been running very well lately. In fact I havent driven it in about two weeks. This summer I did a LIM gasket replacement. After doing this I flushed the coolant - which was very sludgy from the oil that found its way into the coolant. It drove fairly well after the gasket job. About a month ago I starting having an overheating issue. The temp would run around 210 and higher. I got the temp to stay lower when I bled the coolant system of air. That helped for a while. The last day i drove it, the temp got into the 260 range which made the temp light to come on. I pulled over, noticed some smoke coming from the engine. Let it cool down for 20 minutes, and checked the coolant. I had to add about a gallon to the radiator, which was full just a few days prior. When I got the car home and cool, I added more water to the radiator. A minute after, I heard the water dripping onto the ground. I looked under the car to see where exactly it was coming from. Im assuming it was leaking from either the water pump or the a/c compressor, or at least thats the area it was dripping from. It seemed to be dripping out of some kind of pan with a few holes in it. Dont know what this is to, but i think thats right under the a/c compressor. So I just dont know what to do to fix this issue. Sorry for the rant but any help is greatly appreciated! Thanks!
