oil puddle on top of intake
97GPJJ
driving around in my car and stopped cause i smelled something funny. when i came to a stop my car started smoking and i pop the hood and looked and theres a big puddle of oil and maybe anti freeze
I have just done both upper and lower (plenum) gaskets 2 days prior and cleaned everything . i talked to a friend of mine and he told me i probaby need a new motor
i cant afford a new motor someone please help
you use thread sealant on the lim bolts? if not that could be where the leaks are from.
any pics of said puddles?
take a paper towel, fold it up into a square, then wipe under the valve coves lip. it could leaking v/c gaskets.
if they are dry, clean the puddle up, then spray it all down with brake cleaner, then watch it closely to see where its coming from over the next day or so.
when you mop the puddle up try to see if its a mix or just oil, its hard to tell in the pics what it is.
and is it just that one bolt valley with a puddle?
idk if its just the picture but it does look to be a little greenish... hopefully not but do what scotty said and go from there
you know what it does look greenish, and there looks to be a green dot on the edge of the t stat housing, maybe thats your leak?
yes it just that bolt valley
