Oil Pressure Sensor Location
it leaks bad when it goes bad, starts out small gets real bad fast.
take your pass side wheel off look at the oil filter, just past it is a sensor with a plug, if its leaking the plug will be wet with oil.
to change it, reach in, un plug it, then put a small pail under it cause oils gonna leak out when you remove it. use channel lock pliers reach in un screw it, same for the install, but stop when its snug, just into the thread sealant on the new sensor or you WILL split the housing.
