The rubber part of the transmission cooler line seems to be very oily (or maybe describe it as oil mixed with dirty cover the rubber part of the line). And I can see the oil dirt mixture on the plastic air dam under the line. But when I checked the transmission fluid level, the level is only a tiny bit lower than the full mark so it seems I am not losing fluid(or losing very very very slowly since I am not sure whether they add transmission fluid to the full mark when I changed the fluid 5 month ago). I placed a cardboard under the car overnight and there is nothing on the cardboard. Is it normal to have a oily transmission cooler line? Maybe transmission fluid can seep slowly from the rubber or the fitting? Is it something to worry about?
The car is a 2005 Grand Prix base model. Thank you for your help!
