Oil light on 97
jc71corvette2
The oil is fine. I keep getting low oil level on the gp. I reset the light by holding reset and light goes off when I start up next time. So then when driving it goes back on right away . Any clue guys
#429
So you'll probably have to drain the oil first, wait til your next oil change if you want. There should be an o-ring on it, so make sure the surface is clean before installing the new one. I'd use a crescent wrench on it.
The oil pressure light by the filter will show this on the dash, if that is coming up either you have zero oil pressure or the sensor died.
The low oil light is the one on the pan.
