Oil light in dash on and off Oil level OK. 08 Base
veener79
Got a weird issues that just started on my wife's car. The Oil pressure light on the dash is coming on and off at times. This morning she informed after getting to work it was on about the first 5min of her drive. The oil level was good on it this morning when she left (checked the dip stick). Nothing on the display showing low oil either. The rest of her 30+min drive the light was off. For the first 5 mins of driving there was speeds up to 45mph. No engine noises.
Not sure if it might be the oil pressure sending unit or the sensor. In looking it seems they are different parts. What might be the best way to check this?
I do not think this would have anything to do with it. At the same time the car is telling her to check her gas cap. It is tight. Thinking I just need to replace it.
We are looking to trade this car in in the next month or two. Trying to keep large costs down.
Thank for your help.
Check the sending unit itself. Not sure on the 04+ cars, but I know the older ones had an issue with failing internally and letting oil leak into the connector and some failed altogether attempting to empty all the oil from the engine.
