Im noticing an oil leak on my 02 GTP. I pressure washed the engine and best I can tell its coming down around the crank pulley area. Ive read the 3.8 engines usually don't have a issue with the crank seal leaking.. if not that then what else could it be. Its so tight in there its hard to tell where its coming from. I checked the oil sender and it looks dry. Here is a pic.. ( looks like I need a new motor mount as well )
