MoarkatsINmuhtrailer
Removed the engine and trans out the top to swap a new tranny in..
Dropped everything back in and reinstalled the oil filter adapter with a new gasket. Started the engine up and let it idle for a bit, then it started pissing out of from the adapter and it is coming from the seal between the adapter and the engine.
I removed it once again, got another gasket, felpro mind you, made sure all the old gasket was off the adapter and got as much off as i could of the engine with a roloc...reinstalled it and it is once again leaking.
Any ideas at all? Should I double gasket it?
