    TIPS:
Oil change deals
TheOtherNick
The mod from over yonder
Well as some you know I am now an Amsoil dealer. I just recently got everything figured out on shipping and what not and am ready to start selling products. I can get Amsoil product, I can also get some Wix, mothers,twin air, and Ngk products. All oil changes come with the larger oil filter. Acdelco number PF 52 this bumps your oil capacity up to 5qts even. The factory size oil filter is available open request. I can also set up packages for other makes and models including motor cycles. I just need year make model and oil capacity. Thanks Nick
Oil is avaible in 5w-30 10w-30 or weights available open request. Prices vary
7500 mile/6month oil change $35.00+ shipping
Includes 5qts of Amsoil xl synthetic engine oil with a wix filter
15000 for the first change/25000 mile or 1 year oil change $55.00+ shipping
Includes 5qts of Amsoil 100% synthetic motor oil with an Amsoil Ea oil filter
I was wondering how you were claiming such long change intervals till you mentioned larger oil filter.
Nice!
Edit: Thanks for the tip today lol
It is the same interval with the factory size oil filter.
Hows that possible? The filter is the primary issue with oil change intervals so if these filters are larger, there is more filter material available which means it should last longer.
You can extend the oil change interval past 25,000 mile mark with an oil analysis. These are the recommended intervals from amsoil.
Not looking for an argument, but more info since i'm not totally inclined on Amsoil. But what i do know is that after about 1200-1800 miles on conventional or synthetics the detergents that clean are already burnt out of the oil. Just because it guards againest friction and doesn't break down for another 4000 or 10000 miles doesn't mean you should run that long. At that point there is nothing good left in that oil except for wear protection. Unless you do an engine flush every other oil change why would you EVER run oil this long!
