oil and boost gauge
ahrns81
im trying to hook up my oil pressure and boost gauge can some one tell me where to plug my boost gauge into my superchrger for my boost? and where to put my oil pressure gauge on my block to read the oil pressure
T into the map sensor line for boost gauge.
For oil press remove the factory sending unit and run the line there. It goes into the oil filter adapter.
Tap here for the boost gauge
And replace the oil sending unit (behind the oil filter) with the sending unit that comes with the gauge. You will prolly need a thread adapter for the aftermarket sending unit. I found mine at Oreillys
