archemedes
I'm not sure who told you to put dye in the oil but i have NEVER heard of that. Think about it, When dye is used it is to tell you where a leak is happening and is usually used on clear liquids or gasses.Perfect example would be freon in the a/c system. Or on something that when it leaks it is hard to see. Don't you think you can see where the oil is comming from when it leaks out?
the dye is uv and shows up under black light, and is the proper method for detecting a leak in any fluid
