OEM Wiring???
2005GTX
Hey! Does anyone know if our cars are prewired form the factory for all available options? For example, lets say you can did not come with leather heated seats.. You get a set and u install them. Will the wiring for the heated seats already be in the dash and under the carpet? I know some manufacturers have the wiring already run for stuff like that...
I would say most aren't wired.
The question is asked about the heads up display wiring from time to time, it's just the luck of the draw if the pigtails are behind the cluster.
You'll have to pull up the carpet and see if any open plugs are there.
Some have the plugs for a digital dic and heads up display but I don't there is for heated seats. However the heated seats might plug right in and work, i believe the harness connections are the same.
