OBD blue tooth connector for Torque Pro to read ABS
mrbreezeet1
I have this connector.
Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light https://www.amazon.com/dp/B005NLQAH...abc_8KVQAGNTZBBHYYS4GH3C?_encoding=UTF8&psc=1
I understand Torque Pro will read ABS.
Using Torque Pro, and the above connecter, it tries to communicate to read ABS, but won't.
I thought I read on here that connector won't work for ABS.
Do you think it is the blue tooth connector I am trying to use?
Is there a blue tooth connector that will allow me to read ABS codes, using Torque Pro, or a different App that will read ABS codes, using the connector I have?
I have a 2001 Grand Prix SE.
Actually, I did try that app a while back, it tries to connect, but won't.
I don't know if it's my adaptor?
I thought I read on here, this adapter won't read ABS?
Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light Amazon.com
that bafx should work fine. that app is a bit of a pita to get to connect. iirc, open the app first, then plug in the bafx. then tap the blue tooth icon up top the screen.
might need to enter the unlock code for the bafx. most are 0000 iirc. should be in your directions.
