o4gtp runnin hot bad tension pulley
blackcompg
my o4 gtp compg is runnin hott n i have brown sludge n my radiator n motor i thinkin its my supercharger tension idler pulley i hear a squeakin sound from by my water pump
Er uh...Hi.. welcome.
Do you need some procedures for all the work you are about to do or are you bringin her into a shop?
Darn Matt...nice job on the move to the proper section, but ya make me saying welcome and not giving the advice look kinda... doucheee lol
Don't say it.. Don't... Eh...I said Don't... I know Canadians..:th_laugh-lol3:
Shouldn't we call you Sam? ... Christ..that f'n first name thread has me wondering about my own name. I need a drink, but Nick emptied the fridge as usual.
He always does...even at my place. Maybe we need to empty all the booze into pop bottles to throw him off
You forgot that we can piss into the beer bottles to simulate the correct color beverage.
OP...I'd be sorry for off tracking your topic...but I'm laughing too hard.
Your not the only one.
To try and keep this in the same zip code...sounds like you've got teh case of the dexlove. Remove the supercharger belt and start it...if the sound goes away then you know for sure it is a pulley related to the blower.
What the hell is going on in here?
Brown sludge, pee in beer bottles, bad pumps...wtf
Matt you forgot to mention that he should check his thermostat, if it ain't opening, its backing up and could damage the water pump as well as not cool. He should just replace it anyways for the $2 it costs
wen the car getts hot there is water cumin from that plastic elbow from the water pump to the engine..i changed the termostat n the watter started flowin but n think it got stuck again...if i just change my radiator n fix my pulley will every thing be ok..will i have a problem cuz my temp went n the red
Air bubble. Crazy temp fluxuation. And its probably right by the T-Stat...bleed the sytem while its running.
I don't think this is one of those cases where you tell the OP to go get this and go get that, put it in and you're good to go... Take it to a mechanic, explain what is going on, mention the plastic elbow needing to be replaced, get an honest quote.
If you don't like those numbers they give you, then start rolling up your sleeves and prepare to get dirty and possibly mess it up even more than it already is if you have no mechanical inclination at all.
