O2 sims
91z
I am looking for a good o2 simulator that could handle the elements of minnesota weather! Something that I wouldnt have to cut wires to install. I have looked on ebay and saw some that looked like a threaded fitting to space the sensor away from the pipe, but not sure how that works or if it would. Im not haveing any trouble codes just want to get ride of all the flow robbing bends and restrictions. Any help would be great!
Thanks that looks like what I need! :th_thumbsup-wink: But I am still wondering the purpose of putting the spacer in between the o2 and the pipe just for heck of it. Nothing like a little knowledge!
spacer? what spacer? instead of plugging in the o2 sensor you plug that little magic box in and it mimics the signal from an o2 sensor. that way you dont need to run a rear one and can plug it off and remove the cat.
I saw it on ebay while looking at sims. It just looks like a spacer. They say that you can just put it in and if you dont want to use it then you can remove it. Sounds like some sort of info mercial i know ROFLMAO . Ill ask one of the sellers and see what they say and let you know.
