Not good
starscr33m
I'm in the middle of taking out my trans and the two trans lines on the bottom are stuck. The nut that's is on the end of the lines is rusted to the line itself so whenever I try to take the line off it turns the whole thing...not just the nut. any suggestions on how I can get the lines off the transmission?
Are you planning on reusing the cooler lines? If not, just cut them and get a socket on there.
If you are going to reuse them, then soak them with penetrating fluid and try it again.
