Noob Question regarding thermostats and spark plugs
NewYorkGTP
I have a 2000 GTP and recently installed an SLP airbox with a K&N air filter. That is the only performance mod.
Would I be able to install a 180 thermostat along with TR8 spark plugs? According to ZZP, the TR8's:
"When eliminating KR is top priority, when changing your plugs every 6k miles isn't an issue, or when you must push the limits of performance the TR8 race plug does the trick. It is 4 heat ranges colder than stock."
They're only a few dollars more than the standard plugs and was wondering if the plugs running colder would throw a code or make a difference at all with barely any other mods. Thanks!
Unless you are tuned for the 180* stat, leave the stock 195 in place. And you want the hottest spark possible, so dropping 4 heat ranges would probably not be in your best intrest. Either run copper or the stock irridiums and call it a day. Oh, and don't over oil the K&N as they are known to coat the MAF sensor wires and cause issues. Also be sure to run at least 91 octane fuel.
4) Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK's. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark you can get away with...so running a super cold plug on a larger pulley to combat knock isn't the best plan...OEM replacement ACDelco's, AL606's, and AL605's are basically for stock cars or very small bolt-ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
AC Delco Factory Replacements: Stock
Autolite 606: Stock
Autolite 605: 1 Heat Range Cooler
NGK TR55: 1 Heat Range Cooler
Autolite 104: 2 Heat Ranges Cooler
NGK TR6: 2 Heat Ranges Cooler
Autolite 103: 3 Heat Ranges Cooler
Honestly you can get away with running a 180* thermostat and at least AL605 plugs. Im running both and have no issues at all,car takes a bit longer to get hot which I prefer. And my gas mileage has not dropped.
When I did my 180* just before my tune I got BAD heat swings. Car would get really hot then cool off the get really hot then cool off.
