Noob question! Mods!
ItsMolly
Hello! I'm quite new to the forums and I just recently purchased an 02 Grand Prix GTP.
I have a set $500 spending limit for mods, which mods should I do!?
Hello kitty stickers, fuzzy seat covers, fuzzy steering wheel covers , floor mats, blue headlights, and hub caps - $150
Turbo whistle, fuzzy dice on rear view mirror, carbon fiber taped hood and trunk, neon under glow, big wing, electric supercharger, 8" cold air intake, flame painted front - $250
don't bother with bigger injectors unless switching to E85, and if you do either, you will need to tune it. headers and an mps would be a good start.
let me echo what everyone else said, learn to read because this question get's asked all the time because people fail to look around the forum for less than a minute.
Put that $500 into a savings account for the transmission you'll have to replace. If the transmission hasn't been replaced already. ^_^
What has been replaced on it already? You doing all the work yourself? How many miles on it currently? If doing all the work then I'd suggest new Dorman front lower control arms, front sway bar, struts/springs/mounts at all 4 corners, valve cover gaskets/grommets, LIM gaskets, engine and trans mounts. Once you get a solid base then you can mod it. No sense in trying to mod something that has a bunch of broken/worn out parts on it already.
No one made fun of you.....you asked the most asked question in the world here. When all you had to do is use some of you're brain cells and click the search button.....if you want a forum where everyone will leg hump you.....take that 500 bucks and sell the gtp and buy a Honda.
