noob question about two bolts in the suspension..
OhsoKleaN
are these bolts in the picture known to seize up?? tried to take them off but couldnt turn them at all. help!! lol
the nuts on the back of the bolt came rite off... am i supposed to hammer them out a little??
squirt some powerblaster on them and let it soak in for a day or so. you said you got the nuts off but cant get the bolts out? put the nuts back on until they are fluch with the end of the bolts and then hit it with a hammer that shoudl get them out
just make sure you put the nuts flush on the end of the bolt or otherwise your not getting the nuts on or off those bolts
Yes, the bolts holding your control arm to the strut need to be hammered out. There are lines on the bolt near the head to prevent any movement whatsoever while assembled. It'll take 15-20 solid hammer drops to break them loose. I'd recommend putting some Never-Seize on them to help in the future.
Oh i know they dont spin out I was talking the actual nuts
once you break the nut back it of till its a little over flush with the bolt and pound it out
the bolts are splinned so u can take the nut off without bolt spinning. after you get the nut off u pound them out make sure u dont mess up the threads, i use a brass hammer cus it wont damadge any threads:th_thumbsup-wink:
It looks like the top bolt is not the oem bolt. If you hit that one you risk damaging the threads and may cross-thread the nut when you re-assemble
Use a brass drift if you have one. Just don't go pounding any bolts. If you don't have a brass drift use a large centering punch.
Pic is from Geddy's how to thread for wheel hubs.
