andante147
I just bought an '03 GTP with 125K. I plan to get more complete service records from a dealer in another suburb. In the mean time, I'm not sure if these symptoms are related ..
NOISE -
I haven't been at highway speeds yet for any length of time, but in all of my suburban driving if I've accelerated to 40 or 50 mph, as soon as I let off the gas there's a definite noise...it's a "wooooo" sound - (pardon my musician's observation, but it's about a G above middle C, and varies a bit with speed)... or you could compare it to the higher sound semi tires make on an interstate, or a bit like a shop vac running.
It's totally consistent, and stops the second I tap the accelerator.
ABS/TC Lights? - I wondered if this was a bad wheel hub/hubs because these lights are on - but suspect not because there's no noise during acceleration.
Supercharger? - I assume it's not the supercharger functioning normally - why would it make sound when I'm not touching the gas?
Tires? - it has fairly new tires, but the noise is so specific to the application of the gas pedal that it seems unlikely.
So I wondered about a transmission issue... something like a torque converter hanging up in some way?
HARD SHIFT - I had just ONE very noticeable hard downshift in traffic yesterday - it just jerked from 2 to 1 (I think) Only once so far.
I've been reading about trans coolers and shift kits, and might install as preventive maintenance, but I'm also curious if this noise is trans related.
Thanks - sorry so long...
NOISE -
