I have an 01 gtp bone stock and have a rubbing/grinding type noise coming from the passenger side of the engine bay. It goes away after giving it some throttle. At first after researching I thought sc coupler but I disconnected the sc belt and turned the pulley on the sc and it had no play to it. I also started the car and it still made the noise while the sc belt was off so I know it's not that. The bad thing is I don't have a heated garage and it's been really cold in combination of me workin 60-70 hrs per week so my time is limited.
Maybe water pump? Even though no visible leaks nor overheating
I recently changed idler pulley and the car has 113k on it. It also had a list of stuff done when I bought the car. Sc gasket, valve cover gasket, sc oil change, brakes, cv boots, thermostat and some others I can't think of off the top of my head.
Any help would be appreciated
