No spark
Rustrocket
So last week was driving along and the car just stalled. Wouldn't restart. Got it towed home and started checking it out.
Poor fuel pressure, so it got a new pump and filter. Still no start, checked the ignition. Nothing at the coil, ground under the icm was fine. Cps harness looked good, changed the cps and the balancer(puller stripped out the threads). Still nothing. Swapped in a spare icm and still nothing.
I'm out of ideas other than broken wire harnesses. Not throwing any codes, and according to my torque app its calling for 0 degrees of timing while cranking, if that helps. Any help would be appreciated.
Got it running. Turns out the main ignition relay went bad. Feel like a fool, but at least this fool has a car that runs like a watch.
